Is it possible to start TestStand to automatically load with a custom environment
I've created my own TestStand environment file:
But every time I open TestStand, it defaults to <Global> environment. And I have to open Configure --> Environment to change to my own environment, and press Set Engine Environment, which you then you have to wait for it to basically restart.  It's a time consuming effort every time you want to start TestStand!
Is it possible to change it so that it defaults to using my own custom environment?
Thanks in advance for any guidance!
Christopher Farmer
Certified LabVIEW Architect and LabVIEW Champion
NI Silver Partner and Automated Production Test Specialty Premier Partner
https://wiredinsoftware.com.au
DQMH Trusted Advisor
(3,679 Views)
Accepted by topic author ChrisFarmerWIS
Hi Christopher,
I had similar problem and my solution (or rather a workaround) was to change shortcut target to:
"C:\Program Files (x86)\National Instruments\TestStand 2019\Bin\SeqEdit.exe" /env "MY PATH TO .tsenv file"
Mateusz Owczarek
Certified TestStand Architect
(3,633 Views)
Thanks Mateusz.  Great tip!
Christopher Farmer
(3,621 Views)
You're welcome, glad I could help 🙂
Mateusz Owczarek
(3,614 Views)
This is not a workaround this is actually how NI expects you to do it.  I opened a support ticket with them in the past and this was exactly how they instructed me to do it.
David Wilt
The New Standard LLC
(3,490 Views)
Hi everyone,
for anyone working with environments and/or multiple Teststand versions: I put together a small open-source tool called Environment Toolkit for TestStand that helps manage and launch TestStand setups using simple profiles (version + environment), via CLI or GUI.
You can install it through vipm.io
or github.com
Best,
Juan
(924 Views)
If it this is like NI exepts to do it whats about the CfgLocation (e.g. Users.ini)?
My workaround is that i have for every environment I use I created a registryfile to switch between the environemnts:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\National Instruments\TestStand\23.0]
"CfgLocation"="D:\\teststand_environment\\CommonAppData\\Cfg"
"DefaultEnvironmentPath"="D:\\teststand_environment\\tw_teststand_environment.tsenv"
(902 Views)
