Is it possible to calculate arrays of the same size element-wise in TestStand?
See subject!
I mean   array_c=array_a - array_b like it is possible in Labview?
Many thanks in advance.
(3,190 Views)
 I just found the answer a couple of messages before:  so I need to run the calculation statement in a loop with the loop-index as the index parameter of the operands, so step by step for each index. That's ok.
Thanks guys!
(3,184 Views)
Or you could pass the arrays in and out of a VI (or other code module that has the desired operations).
(3,182 Views)
