NI TestStand
Is it possible to access data within the StationGlobals from a custom Operator Interface without a sequence running?
I'm trying to change the Station Globals from a custom interface, however I can't figure out how to get a context to get at those values without a callback from a running execution. Any ideas?
(3,323 Views)
You dont say which language but here is an example for the LabVIEW (6.1) Operator Interface.
I use this to detect if a StopOnFail boolean is available and if it is get its value.
Using the Engine Reference, I get a Reference to the StationGlobals properties. I can then use the method Exists() to see if my actual StationGlobal variable exists and if it does call the method GetValBoolean.
Hope this helps
Ray Farmer
Regards
Ray Farmer
(3,323 Views)
Sorry, I forgot to mention I'm writing CVI. I'll see what I can do with the LabView version.
(3,323 Views)
