03-12-2019 08:02 AM
I'm currently using an evaluation license of Teststand 2017 SP1, to see if i could use it to connect to my HiL-Testbench via XiL-API. I also installed the XiL-API step package. I used one of the XiL-API examples coming with Teststand wich returns a run-time error.
I already googled it, but can't find any solution. Does anyone know where this error is coming from ?
Thank you
Stephan
03-20-2019 10:04 AM
Hi Stephan,
do you by any chance run this example by Operator Interface instead of Sequence editor? This could be potentially the reason.
10-09-2019 01:14 PM
I'm getting the exact same error, definitely running from the Sequence Editor and not the OI.
