Invalid LV Queue Ref in TestStand
having trouble storing LabVIEW queue refs in TestStand: I'm trying to have an asynchronous LabVIEW process running in parallel to the regular test sequence. Communication with the async process takes places using a LV queue.
So what I do:
1.) Call a VI that sets up the queues and returns the Q refs
2.) Store the Q refs in Numeric variable within TestStand
so far, it seems to work. When stepping into the VI and probing the references, the numeric values correspond to those TestStand shows in the local variables shown during the execution
3.) Call another VI that checks the queues for sanity first of all (and fails: Get Queue Status primitive returns Error 1)
when probing this VI, the numeric representation of the queue refs seems to be ok.
So... TestStand is only used for storing the refs which should be ok according to the manual.
Any ideas?
Cheers
Oli
Message 1 of 23
(7,708 Views)
Clicked the Post button to fast Smiley Wink
I started the Trace Toolkit. As you can see in the screenshot attached, it identifies the open queue refs as memory leaks.
Is it possible that due the different context between TestStand and LabVIEW the queue refs are diposed?
BTW Using TS 2013 & LV2012SP1
Message 2 of 23
(7,705 Views)
Hi Oli,
which versions of LabVIEW and TestStand do you use?
When I understand right, you have a queue reference from a LabVIEW VI and you want to transmit the reference to other steps in TestStand. right? Can you post a little sequence?
Best regards
suse
______________________________
Certified LabVIEW Developer (CLD)
Message 3 of 23
(7,661 Views)
I would very highly recommend not storing the ref nums in TestStand.  Instead, use an Action Engine to store your queue and send the data.  I do this all the time and it works beautifully.
GCentral
Message 4 of 23
(7,657 Views)
While i also recommend to store LV internal data in an Action Engine, it should be possible to pass the references to TS and pick them up in the next module.
Can you please post an example, Oli?
I suspect an issue with "Application Instances". Is it possible, that one of the modules is running in the context of a LV project while the other one isn't?
Please check the step settings for usage of "lvproj"-file...
Norbert
Norbert
Expert: Geometry
Message 5 of 23
(7,653 Views)
I think it might be a LabVIEW issue. Which versions do you use??? Maybe there is a patch for this reference issue.
Message 6 of 23
(7,652 Views)
OK, i tested it out and encountered the same issue..... with a certain inconsistency!
I used three separate VIs essentially encapsulating the three functions:
- Obtain Queue
- Enqueue
- Get Queue Status
I created an I32 queue using obtain, passed that refnum out. As TS doesn't have a type for "LV Queue" (as it depends on the datatype in the queue!), it is simply stored as numeric.
Just like you, Oli, i've seen the address of the queue correctly passed to TS. Noteably, the probe in "QueueRef Out" is of type variant telling me that i used an unnamed queue.
Passing the RefNum to the Get Queue Status VI works fine. A probe on "QueueRef In" tells me the correct address, it even states "Unnamed". I haven't checked for named queues.......
So let's enqueue things....
Here comes the inconsistency:
When using the same QueueRef In element as at Get Queue Status, the probe in the Enqueue VI tells me: Not a RefNum!
I don't know where this derives from, but i have found a solution: Pass the QueueRef to the Enqueue VI as numeric value. In the module, use the Typecast function to cast it to a queue RefNum (beware to use the identical datatype as for creation!).
This works well on my machine, should work for you as well....
Norbert
Norbert
Expert: Geometry
Message 7 of 23
(7,644 Views)
Hi Norbert,
thanks for your help. Already feared, I nedd such a workaround.
Considering of using a named queue instead a numeric and a typecast and then just use the queues' name. If I have to change the interface anyway...
Best Regards from Geneva Smiley Happy
Oli
Message 8 of 23
(7,635 Views)
Me again,
the I32 and the typecast did not fix the problem... the behaviour is very similar. After passing the (typecasted reference) to the VI, the first Queue primitive (tried Get Status and Dequeue) throws Error 1
WIll try the String version....
Message 9 of 23
(7,628 Views)
Oli,
have you used the type cast as shown in the following example)?
Norbert
PS: Due to a disturbing bug in Lithium only the screenshot 😞
Norbert
Expert: Geometry
Message 10 of 23
(7,612 Views)
