05-31-2021 03:55 AM
I have to create an interface in TestStand based on LabVIEW.
There is an example in the TestStand User Interface:
C:\Users\Public\Documents\National Instruments\TestStand 2019 (32-bit)\UserInterfaces\Simple\LabVIEW
I can choose the results of which UUT to show: in Executions (shown in the picture).
Question:
How to show the results of all UUTs at the same time without clicking on Executions? as in the picture num. 2
05-31-2021 11:55 AM
You will have to have multiple Execution View Managers and connect the execution views to them independently. I've done it before and it's not that bad but you do have to know which execution is assigned to which manager.
06-03-2021 06:05 AM
Good day,
Can you give example solution this problem ?
06-07-2021 11:11 AM
There is this out there: https://forums.ni.com/t5/Example-Code/Multi-Window-TestStand-User-Interface-Example-LabVIEW/ta-p/362...
Not sure it is exactly how I would do it as I haven't opened it but it could be a start for you.
06-07-2021 11:17 AM
Thank you for help!
06-10-2021 03:33 AM
Good day,
When I run Your program, opened 4 windows (one window for every UUT).
How can I "command" to open all UUT in one window, not in four ?
