05-12-2006 10:30 AM
05-13-2006 04:25 AM
If you have finished with a development license on one system and want to use it on another system, you should remove it from the orignal system. You can get a new activation code for that new system, either via the website, or direct during the installation, or via telephone.
If you then create a new deployment for another target sytem. I think you will need a new deployment license as your original deployment license is still being used on your original target system.
If in doubt speak direct to your local NI representive.
Regards
Ray Farmer
05-15-2006 07:56 AM
Thanks for attempting to answer my question Ray. But apparently I did not do a good job of expressing my question.
I am wondering if there is some way to avoid the development license removal process (uninstall) on the original PC, and instead just twiddle a few bits so that the debug license number and debug activation code are used on that PC. This is my first project using TestStand, so I do not know how many ".ini" files or other settings might get lost during the unistall (Development) and re-install (Debug) of my LabView and TestStand software. From my perspective (it's working, don't touch it), it would be best if I could leave everything the exactly the way it is -- except for the license number.
05-15-2006 08:32 AM
I think all you would have to do is use the NI License Manager to set the TestStand to the debug license and then you can re use you development license else where and remove the development licence file from the system.
Regards
Ray Farmer
05-15-2006 08:43 AM
05-15-2006 08:58 AM
Its installed as part of your TestStand or other NI products. Its just another way of activating your NI products as you can download the different license files from NI.
Regards
Ray Farmer
05-15-2006 10:54 AM
Rich -
Go to Start>>All Programs>>National Instruments>>NI License Manager to access the license manager. Right-click on the license that you want to deactivate to bring up the context menu with the Deactivate command.
- David
05-16-2006 12:37 PM
Thanks David. I guess I usually use my desktop shortcuts to launch TestStand and LabView. I never took notice of the License Manager application.
However, when I right click the "Debug Deployment Environment" text next to the green light, the only choice that shows up is "Activate . . . "
05-16-2006 05:23 PM
