Input variables
Hi guys, I'm new of Teststand and I'm trying to learn.
Well I did an one step application like the one attached.
I'm a little bit confused on how to set the input variables. I want that taststand ask me to set them.
Another question is how can I see the result of my test in the final report? I want to see the result of the sum and of the product. Can you help me?
Thank you
(3,907 Views)
in particular about the fact that I want to see the outputs on the report I'm following these steps as I have read them in the guide:
On the Properties tab of the Step Settings pane, complete the following steps to add the
numeric array and other values to the report.
a. Click Additional Results to show the Additional Results panel.
b. Place a checkmark in the measurements [Out] parameter checkbox to log the output
value of the parameter.
But it doesn't work........
(3,901 Views)
Accepted by inuyasha84
Look at the changes I've made to your VI and sequence.  Is this what you are trying to achieve?
Kelly Bersch
Certified LabVIEW Developer
Kudos are always welcome
(3,868 Views)
Hi there, thank you for your help. I found out the error I did few days ago but I didn't find the message here on the forum to update it.
By the way again thank you.
(3,846 Views)
