NI TestStand
In Teststand, can I pass input parameters to running a LabVIEW VI?
Highlighted
I would like to know how to pass inputs to already running LabVIEW VI through NI Teststand.
(193 Views)
Highlighted
Is this the user interface or just a VI that you call asynchronously from your sequence file?  How does the VI get started?  There are different mechanisms depending on the use case.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(150 Views)
Highlighted
Thank you for reply.
I think, it is just a VI that I am calling asynchronously from my sequence file. I am calling a VI with one set of inputs and then again I want to send new set of inputs to same VI which is already in running state.
I am beginner on TestStand and not sure if the above information make sense.
(128 Views)
Highlighted
(97 Views)
Highlighted
Thank you for the information and links.
I now understand that the VI should be run asynchronous and can be stopped from Test stand. My intend was to pass parameters too.  I have gone through your sample VI & seq, I get it now that we can do it but I am looking for some an NI example/sample VI and Seq for this application.
(88 Views)
