In Teststand, can I pass input parameters to running a LabVIEW VI?
I would like to know how to pass inputs to already running LabVIEW VI through NI Teststand.
(2,095 Views)
Is this the user interface or just a VI that you call asynchronously from your sequence file?  How does the VI get started?  There are different mechanisms depending on the use case.
jigg
CTA, CLA
testeract.com
(2,052 Views)
Thank you for reply.
I think, it is just a VI that I am calling asynchronously from my sequence file. I am calling a VI with one set of inputs and then again I want to send new set of inputs to same VI which is already in running state.
I am beginner on TestStand and not sure if the above information make sense.
(2,030 Views)
Thank you for the information and links.
I now understand that the VI should be run asynchronous and can be stopped from Test stand. My intend was to pass parameters too.  I have gone through your sample VI & seq, I get it now that we can do it but I am looking for some an NI example/sample VI and Seq for this application.
(1,990 Views)
