05-22-2020 05:43 PM
I would like to know how to pass inputs to already running LabVIEW VI through NI Teststand.
05-22-2020 11:29 PM
Is this the user interface or just a VI that you call asynchronously from your sequence file? How does the VI get started? There are different mechanisms depending on the use case.
05-23-2020 09:25 PM
Thank you for reply.
I think, it is just a VI that I am calling asynchronously from my sequence file. I am calling a VI with one set of inputs and then again I want to send new set of inputs to same VI which is already in running state.
I am beginner on TestStand and not sure if the above information make sense.
05-24-2020 11:07 PM
Here's an example: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000g0sqSAA&l=en-US
Here's an old post about it: https://forums.ni.com/t5/NI-TestStand/continuously-run-a-vi-and-pass-data-to-it-while-going-through/...
Hope this helps,
05-25-2020 08:12 AM
Thank you for the information and links.
I now understand that the VI should be run asynchronous and can be stopped from Test stand. My intend was to pass parameters too. I have gone through your sample VI & seq, I get it now that we can do it but I am looking for some an NI example/sample VI and Seq for this application.
