03-28-2018 07:19 AM
I have configured a TestStand sequence with a single NumericLimitTest step (using the LabVIEW Adapter but I am not sure that is relevant). My step has a Lower Limit value of INF. I can export my sequence properties successfully (including the LL), using the Import/Export Properties... in the TS Tool menu. However when I import the properties back into my sequence, my LL of INF gets modified to "Infinity" (see post-import screen shot below).
At run-time my sequence works fine, TestStand recognises "Infinity" as infinity but it is a little bit strange that it is not recognised at design time.
I am guessing this is something that has been introduced to TS recently (ish) as I don't recall it working in that way on TS2012 (my previous version). Any thoughts, suggestions or clarifications about why TS would work this way greatly received.
Steve
03-29-2018 06:26 AM
03-29-2018 07:44 AM
Thanks Jeurgen
I am running TS2016 as well. I have not been able to reproduce the issue today, I have attempted to recreate what I did yesterday and I have also tried a similar sequence that uses the None Adapter both export and import INF limits fine .
If I manage to get it doing it again I will post up the sequence and properties file.
Regards
Steve
