12-02-2019 01:08 PM
I've configured the station options, report options, global variables, etc. but it seems that they are not saved in a workspace or sequence file.
I found where those get stored in these forum: https://forums.ni.com/t5/NI-TestStand/Export-Report-Options-in-Sequence-file-deployment/td-p/3062172...
Is there a way to import these configurations into teststand? we have several people working on the same project on different computers. we are using GIT as a source control and to share the progress, how can we share the configuration of teststand?
12-02-2019 01:34 PM
I would highly advise against sharing TestStand configuration. You will run into more problems than you will solve. Trust me on this one...I've been there and tried that for like 2 days. The problem is that they get saved so often (serioulsy every time you open and close TestStand) that everyone will be bombarded with dialogs and other warnings.
However, environments are a great way for someone to get their machine into different states quickly. You could set a baseline for each project and then when someone moves to a different project they could copy down and use that project's environment.
http://www.ni.com/tutorial/54263/en/
Hope this helps,
12-03-2019 09:23 AM
I will try that right now and reply with the results
12-03-2019 10:47 AM
Ok So I was able to create an environment but then how can I import or copy that environment i created to a workspace? What I mean is how can another person use that environemt I created in their workspace, how can they import it?
12-03-2019 11:25 AM
you cannot use it in a workspace. The cfg gets loaded when the engine starts, long before workspaces are loaded.
You could put it on a shared drive and create a shortcut to TestStand that loads that environment. Or you could distribute with source code control, like GIT.
I want to make it very clear though. It is a bad idea to share configurations. Developers will continually be tromping on each other's cfg files because like I said earlier, TestStand is constantly writing them.
My recommendation is that you get it set up how you like it and create a .nipkg that will install it to a certain location including a shortcut that loads a certain environment. That way people working on the project will just need to install that package and click ont he shortcut.
12-03-2019 01:24 PM
Ok do you have a guide on how to create a shortcut that loads an environment? also a quide on hot to create a .nipkg?
12-05-2019 09:18 AM
This link shows how to start the sequence editor with a defined environment:
https://zone.ni.com/reference/en-XX/help/370052R-01/tsfundamentals/infotopics/tsenv_choosing/
You can just create a shortcut on your desktop, or wherever, and pass that argument to the sequence editor.
As for NIPM you are opening a whole new can of worms there. If you aren't currently using it then you might not want to move to it. Instead of a .nipkg you can just us a batch file to copy the folder you need to the proper locations on the local machine.
