Has anyone created a tool (sequence, stored procedure, etc.) for importing data from a TestStand 1.0.2 database schema into a TestStand 2.0 database schema? I'm using SQL Server 2000. Thanks in advance.
Unfortunately there is no tool for importing data from TestStand 1.0.2 database tables (DB Schemas) into TestStand 2.0 tables. However, you can manually create SQL scripts to copy/move data from the old table structure to the new ones. Also, you can still use the TS 1.X schema in TS 2.0 (Under Configure->Database Options->Schemas you can select TS 1.X Access/SQL (NI) as your default schema.)
Roberto Piacentini National Instruments Applications Engineer www.ni.com/ask
