NI TestStand
Identify the caller sequence from callee sequence in TestStand
Greetings All,
I have two test sequences Test-A and Test-B.
I am using sequence call in Test-A to call Test-B using "New Execution" Method and using sequential model and  "Test UUTs" entry point.
Is there any option to access Test-A sequence variables in Test-B? or Is there any option to check Test-B is called by Test-A.
I am not interested to use parameter pass due to project limitation. Is there any other approach?
Message 1 of 1
(595 Views)
