NI TestStand
I want to copy array of values that is located in Excel to TestStand FileGlobals
I have a little table of parameters in Excel file.
For example it seems so:
Modulation_mode Upconversion_mode
1 3
2 4
And I have 2 FileGlobals in my sequence: Modulation_mode (array of numbers) and Upconversion_mode (array of numbers).
I want to copy a table from Excel table to my FileGlobals accordingly.
How can I do it  ?
Message 1 of 8
(4,855 Views)
Try using the property loader step type.
Attached is an example.
Regards
Ray Farmer
Regards
Ray Farmer
Message 2 of 8
(4,851 Views)
Hi, Roy, thank you for example, it works.
But a table in .xls file became to be terrible.
I have to have this file in simple mode (for user) such as
Modulation_mode
1
2
4
without "terrible" string
Modulation_mode <Prop Name='Modulation_mode' Type='Array' LBound='[0]' HBound='[1]' ElementType='Number'><Value ID='[0]'>1</Value><Value ID='[1]'>2</Value></Prop>
Is this any way to do it beatiful ?
Just values in the table?
Message 3 of 8
(4,846 Views)
Yes it is a bit messy.
Try this example.
There is a down side to defining every element of the array.
Look at the PropertyLoader step properties between the two steps.
Regards
Ray Farmer
Regards
Ray Farmer
Message 4 of 8
(4,840 Views)
Ok, Ray, Thank's.
Message 5 of 8
(4,828 Views)
Hi Ray,
Is this still the only way of loading a set of variables using excel, or do any of the later versions of TestStand have the capacity to read an excel file without all the formatting?
Sean
Message 6 of 8
(4,227 Views)
Hi SeanJ,
I used LabView to do this. I had a table of parameters in excel and I build a VI that extract this parameters in different way. This isn't the faster way to extract information (you need to open a file with LabView and than read your variables) but it works wery well because you can customize everything.
Otherwise, you can format the excel file like a text file with tabulation and than read the text file with TestStand, but I think that you have to re-format the information with a VI or similar for use that easily.
Good work,
Sem
Message 7 of 8
(4,213 Views)
Replying so I can check this thread on another machine.
Message 8 of 8
(2,169 Views)
