I'm using TestStand 2.0/Labview 6i with SQL open statement to do a query. Can you use a variable name with the SQL statement instead of quotes around a value? See example below.
SELECT * FROM STEP_COMMANDS WHERE STEP_COMMANDS.SPEC_NUMBER = '4.5'
I would like to use a variable instead of '4.5'. SPEC_NUMBER is a string type.
SELECT * FROM STEP_COMMANDS WHERE STEP_COMMANDS.SPEC_NUMBER = 'SPEC_NUMBER'
