05-16-2006 08:19 AM
05-16-2006 08:24 AM
05-16-2006 12:29 PM
Hi Marta,
Are these UUTs tested in parallel? If so, you can also consider the batch or parallel models.
JLV
05-17-2006 01:41 AM
thank you very, very match for replies.
No, I don't test UUTs in parallel.
Now I have more question.
I tried yesterday to use BatchModel and in "my" ModelOptions I did
Parameters.ModelOptions.SequentialBatchMode = true
Now I have all UUTs run sequentially, and I have special report for each UUT.
What do you think is this the better way ? ( I must check all options).
05-17-2006 09:37 AM
Hi Marta,
I think you are getting slightly confused on the different process models. Refer to the About the TestStand Process Models tutorial for explanation. The SequentialBatchMode option specifies that the model runs test socket executions one at a time in ascending test socket order.
Besides that, just remember what Ray mentioned in regards to setting the New UUT Report File for Each UUT option under the Report File Pathname tab (Configure >> Report Options). Also note that there will be more options for filenames when you are using the Batch process model versus the Sequential process model.
Just take these notes in mind.
Hope this helps!
05-18-2006 07:09 AM
