NI TestStand
I.e. entire BT address wont print on report
Highlighted
Hello
I am currently struggling with having the called on commands printed onto the UUT report in a one-liner. I can get them printed on the report separate, using several of the CSP String Value Test functions, but would like to add them all together into one long string. I currently do not know how to concentrate the strings. Pleas see attached picture.
Thanks in advance, BR Andedam!
(311 Views)
Highlighted
Accepted by topic author Andedam
Are you able to post your sequence?
(292 Views)
Highlighted
Thanks, I have attached my sequence
BR Andedam
(285 Views)
Highlighted
I must confess I am still not sure what you are trying to do.  Please see the attached.  I have changed your four Tests to Actions and have added a String Value test afterwards.  I have configured the Data Source of the new test to the concatenated results strings from the 4 Actions.
(217 Views)
Highlighted
Hello, first thanks for the reply, although please ignore this post. I have posted a new more detailed post regarding the problem;
https://forums.ni.com/t5/NI-TestStand/Returning-only-final-string-of-SubSequence/td-p/4070330
Thanks!
(208 Views)
