Hello!
I am running TestStand 1.0.1 and I wonder who I can "Run Selected Step" and "Loop on selected steps" in a subSequence in the "TestStand Operator Interface"?
When I am in the main sequence I can go to the "Execute" menu and select "Run Selected Step" or "Loop on selected steps" but, I can�t open a subSequence and run one single test in the subSequence.
If I use the "TestStand - Sequence Editor" there is no problem, here I can open a subSequence and run one single step. But in the production line in our factory the policy is that only the "Operator Interface" shall be used. The feature I need is useful for trouble sho
oting.
I use TestStand to call LabVIEW code.
Jan Inge Gustavsen
