NI TestStand
How to use the Tool menu to load seq file
I would like to use the Tools Menu (using the customizing option) in order to load (or run) a sequence. This particular sequence file has SequenceFileLoad, SequenceFileUnload and MainSequence.
I would like to load the seq file exactly as it is done with File/Open/myseq.seq (which first execute the SequenceFileLoad and than, display the main sequence list of test in a window waiting for F5 or other executing commands)
I examined the other examples in the Tool menu, however, when I use the 'customize' for my seq file nothing happens and the TS is frozen. I have tried to specify either MainSequence or SeqFileLoad but non seems to work.
Any idea?
Rafi
(3,317 Views)
Rafi -
It appears that the LoadCallback causes the OI to be non-responsive. We can look into that. What I recommend is the following.
Create a tool menu sequence open the target sequence file, send a message to the OI to create a window for the target sequence file, and then release the target sequence file.
If you want to run a sequence in the target sequence file, you can just call the sequence using a sequence call step.
See attached sequence files.
Scott Richardson (NI)
Scott Richardson
https://testeract.com
(3,317 Views)
Rafi -
FYI, the hang condition was fixed in TestStand 3.0.
Scott Richardson
(3,317 Views)
Thank you Scott very very much!!
Although I don't fully understand how it works, I was able to test it and then implement it in my system.
It works great, doing exactly what I wanted.
Thanks again.
Rafi
(3,317 Views)
