03-19-2020 01:45 AM
Hi,all
In the Teststand default Simple UI software, we use the Entry point 1 Button to excute the teststand engine and start the UUT test. The Entry point 1 button is a teststand default button control, after it regists the sequenceFileviewmgr connectcommand, then it has the start test function.
From my side, I prefer to use Labview button rather than teststand default button to excute start function,Because labview button can be DIY. So the big problem is that I don`t know how to regist the labview button to the teststand engine that can control the teststand excution.
Thank you in advance!
Open28
03-19-2020 09:46 AM
One approach is in the example here:
%TestStandPublic% or %TestStandPublic64%\Examples\Modifying User Interfaces\Building a TestStand UI with Native Controls\LabVIEW
Hope this helps!
Trent
03-19-2020 09:46 PM
Hi,weaver
Thank you for your rensponse.
It is what i want.
Thank you again.
Open28
