10-05-2018 06:01 AM
is there somewhere a flag in the teststand menue to disable the execution seqFileLoad/unload of a testplan?
Thx
10-09-2018 09:48 AM
Hello Onlyone,
you can disable the load/unload engine callbacks if you use the GetSequenceFileEx Method with the GetSeqFileOptions parameter set to value 0x10.
Best regards
10-10-2018 06:53 AM
And how can i do this in Teststand?
10-11-2018 09:46 AM
Hello OnlyOne,
what do you mean? That is a TestStand API call which you can invoke using expressions or the activeX adapter. There is no way to change the sequence file load behaviour of the sequence editor. What you could do though, is write your own sequence file load tool that disables the load/unload callbacks.
Best regards
