How to temporary disable SeqFileLoad/Unload of testplan
is there somewhere a flag in the teststand menue to disable the execution seqFileLoad/unload of a testplan?
Thx
(2,047 Views)
Hello Onlyone,
you can disable the load/unload engine callbacks if you use the GetSequenceFileEx Method with the GetSeqFileOptions parameter set to value 0x10.
GetSeqFileOptions Constants
Best regards
Andreas Gareis
Senior Applications Engineer, NI
Certified LabVIEW Developer & TestStand Architect
(2,013 Views)
And how can i do this in Teststand?
(1,999 Views)
Hello OnlyOne,
what do you mean? That is a TestStand API call which you can invoke using expressions or the activeX adapter. There is no way to change the sequence file load behaviour of the sequence editor. What you could do though, is write your own sequence file load tool that disables the load/unload callbacks.
Best regards
Andreas Gareis
(1,991 Views)
