NI TestStand
How to tell when a teststand sequence ends in the Simple UI?
Hello Community,
32-bit Teststand 2014
32-bit Labview 2015
I am using the Labview version of Teststand Simple UI.
Where in the Teststand Simple UI can I tell when a sequence file is finished running?
I want to perform an event handler when a sequence ends that will trigger a value change of a control.
Any help would be greatly appreciated.
Thank you
(3,669 Views)
Accepted by topic author MechUnit
I believe that the best option for you is with the UI messages, please refer to this link in order to learn more about it:
http://www.ni.com/tutorial/4532/en/
Luis G.
(3,648 Views)
You could also override the EndExecution event of the ApplicationMgr control. This event is called when an execution ends. You can create a callback within the Register Event Callbacks VI of the user interface to handle the event.
(3,644 Views)
I ended up using the UI messages.
I couldn't get the EndExecution event of the ApplicationMgr control to work, but I did give it a try.
Thank you both for your help! Smiley Happy
(3,624 Views)
