NI TestStand
How to store a relative path in a global variable
I'm using Teststand 2013 and Labview 2013
Is it possible to define a relative path for a global variable in the Teststand? Ex. "..\vector1.hws"
Or I should use the Labview functions to solve this issue?
(3,762 Views)
Accepted by topic author engfpe
Paths are so much easier to manipulate in LabVIEW.  So you could store the relative path as a string and then use LabVIEW to make the absolute path.
I typically store a folder in a global variable and then I can just concatinate the strings to build the absolute path.  For example:
FileGlobals.Folder = "C:\\foo\\bar\\",
Locals.Path = FileGlobals.Folder + "blah.txt"
GCentral
(3,757 Views)
If the file exists within your search directories you can use Engine.FindFile.
Also, you can use Engine.GetTestStandPath to get a base TS path and then make relative additions as crossrulz suggested.
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(3,750 Views)
Yes. It seems that it is easier to manipulate a file path in Labview.
I will store the file name in the TestStand variable and use the Labview to find the absolute path.
(3,737 Views)
