NI TestStand
How to start/stop wireshark capture during a test sequence?
I'd like to start a Wireshark capture running from a command line, have it generate a capture file, and then save the file when the test sequence completes.
Thanks in advance ...
(2,989 Views)
Hi Tezzter,
Can you use LabVIEW modules in your sequence file? You may be able to make calls using the call library function node to interact with wireshark.
Check out this forum post: https://forums.ni.com/t5/LabVIEW/Handling-Wireshark/td-p/3071443
(2,941 Views)
