Modular Data Acquisition
High-Performance Test
From 11:00 PM CDT Friday, Nov 8 - 2:30 PM CDT Saturday, Nov 9, ni.com will undergo system upgrades that may result in temporary service interruption.
06-22-2017 04:28 PM
I'd like to start a Wireshark capture running from a command line, have it generate a capture file, and then save the file when the test sequence completes.
Thanks in advance ...
06-23-2017 04:28 PM
Hi Tezzter,
Can you use LabVIEW modules in your sequence file? You may be able to make calls using the call library function node to interact with wireshark.
Check out this forum post: https://forums.ni.com/t5/LabVIEW/Handling-Wireshark/td-p/3071443
Thanks!
We'll be in touch soon!
