How to set the numeric format through the API
I have an utility that imports limits from external resources and in that utility (C#) I would need to modify the numeric representation  so that what is defined as hexa in the external resource to be displayed as hexa after importing to TS as well.
Can U help me out if this is possible with the API and if so, what is the right methods for it?
Thanks in advance.
(5,830 Views)
Hi!
I'm not sure if I understood you correctly, but I think your problem can be solved, without using API functions. Just double click on the name of variable and there you can change the representation - I attached an image.
If you still want to use API, let me know i will try to find something.
Best regards.
Marcin Twardak
Applications Engineer
(5,772 Views)
Hi twardak.m,
I need to do it through the API to ensure that the same representation is used in both end of our data backend. The data is overwritten at each run so the manual modification would be really inconvenient.
I searched the TS API up and down but find no way to do it not even in TS ( I mean through the API, I'm familiar with the Numeric Format properties window).
Anyway, thanks in advance for the help.
(5,748 Views)
Hi again,
I didn't find straight solution yet, but I think it is good way around:
http://digital.ni.com/public.nsf/allkb/1304B337E03E2E1A86257ACD004BAB06
If you want hexadecimal representation you need to change "%b" to "%x". I'm still keep looking for a better solution...
Best Regards
Marcin Twardak
(5,732 Views)
Accepted by inp3dance
Just a few minutes ago we found this solution working:
  x.NumericFormat = "%#X";  where x is the PropertyObject pointing to the number. It is just not documented anywher for this method  that U can use X for hexa.
(5,724 Views)
I'm really happy you found the solution! Thank you for writting it here, maybe someone else will use it in the future 🙂
Best regards
Marcin Twardak
(5,721 Views)
Thanks for your effort!
(5,705 Views)
