05-10-2006 06:38 AM
05-10-2006 07:02 AM
05-10-2006 07:13 AM
05-10-2006 07:28 AM
It depends,
If the steps follow each other, then for example, you can use RunState.PreviousStep or RunState.NextStep.
If they dont then you have to use RunState.Sequence.Main["step name"] or pass it to Locals/Parameters/FileGlobals/StationGlobals.
Hope this helps
Regards
Ray Farmer
05-10-2006 08:15 AM
05-11-2006 07:00 AM
05-11-2006 10:36 AM
Attached example hopely help you
Check out the text in the MessagePopup.
regards
Ray Farmer
