03-31-2017 10:03 PM
Hello:
when i set sequence file version to auto update, when i save sequence file, will see the version number increase automatically.
Is there any way to retrieve sequence file to a former version?
04-03-2017 09:43 AM
Sequence Files don't save all of the versions like that. That is just a number saved in the file so you can quickly identify what rev it is.
You should be using source code control for this purpose. If you are not using source code control then maybe your IT department does a backup of all the computers?
04-04-2017 08:27 PM
Thanks for your reply~
For the SCC tools, do you have some recommendations?
