01-06-2021 06:56 AM
Hello All,
I need to create a sequence in TestStand(2019-32 bit) which can read a file name xyz.lvlib (LabVIEW library file name) from the local C directory in my PC and store it in a variable. Then I want to take user input (type string) by configuring buttons in message pop up step and compare the user input with the stored variable that is the library file name.
So my first question is how to read the file name from local C directory?
and the second question is how to compare the output state of message pop up(when the user selects a button) with a stored variable ?
Your inputs are very much welcomed.
Thanks in advance!
Preeti
Solved! Go to Solution.
01-10-2021 09:57 AM
01-13-2021 06:57 AM
Hello Jumpod,
Thank you very much!
Your solution helped me. I could read the file names as well as the folder names.
04-09-2021 05:14 AM
06-18-2023 11:53 PM
Preeti_Udapudi Can you help to mark this post as answered? you should give the answered post when you got the solution.
