NI TestStand
How to re-enable tracing?
when running a testplan then there was at the beginning a visible window with the testplan and you could see where the testplan currently executes. Also with the results, limits and PassedFailed.
But now i dont know what happenend. The Tracing is enabled in Configure+StationOptions+[X]Enable Tracing, but still nothing is shown in the execution window.
What is missing?
Thx
(2,268 Views)
Which version of TS are you running? Which UI are you using? What is the process model?
You can set Execution.TracingDisabled in TS steps to disable/re-enable tracing for specific sections of your test. Maybe you have such a step included which disables tracing but you missed to have a second step later re-enabling it.
Norbert
Expert: Geometry
(2,262 Views)
