NI TestStand
How to programmatically write a step/sequence requirement ?
I think everything is in the title ! Smiley Wink
I guess I'll have to directly write in Step.TS.Requirements.Links ? Because I didn't find anything in the Step properties / methods to this...
CLA, CTA, LV Champion
View Cyril Gambini's profile on LinkedIn
This post is made under CC BY 4.0 DEED licensing
(4,335 Views)
You can use the API:
http://forums.ni.com/t5/NI-TestStand/setting-requirements-on-a-TestStand-step-through-the-API-using/...
jigg
CTA, CLA
testeract.com
~Will work for kudos and/or BBQ~
(4,328 Views)
Ok, indeed it works !
My suggestion too...
I didn't try to use the ref on the Requirements from the step because in the API poster, Requirements is set as Read Only... and there's nothing on 'Links'. I should have better looked at it Smiley Embarassed
Thanks !
(4,321 Views)
