02-15-2016 09:36 AM
I agree, not using the TestStand UI at all makes you miss out on a lot of the features that TestStand provides.
I will give the TestStand UI a shot, having a button where you get a popup and put your configurations seems ok.
There is an interest in having data being persistent between runs, so i will go with saving configurations to file.
After a bit of searching and trying, i cannot seem to find how to open a LabVIEW VI from a TestStand UI button, do you have an example or a pointer as to how this is done?
Or did you mean having the configure button in a separate LabVIEW UI? And then starting the TestStand UI from the LabVIEW UI?
I have seen that you can start a TestStand UI and open a certain sequence file through command line arguments.
This could be another solution, to set up the test in a LabVIEW GUI and then start the TestStand UI from it, and have it read parameters from file.
02-15-2016 10:04 AM
You can mix and match TestStand and LabVIEW controls on the same front panel. I figured the button would just be a LabVIEW button that opened a LabVIEW dialog. No TestStand on that portion of the GUI.
However, use the manager controls and TestStand controls to execute the sequence and display status to the user.
02-15-2016 10:17 AM
Oh, of course.
Thank you for all your replies!
