How to personalize your generation report ?
I want to make group/ungroup report.
Like
      +Robot1 PASS/FAIL
              +DI    PASS/FAIL
                         DI0  PASS/FAIL
                         DI1  PASS/FAIL
                         DIn
              +DO  PASS/FAIL
Anyone got an idea about that kind of generation report ?
Best regards
Vincent
Message 1 of 23
(5,212 Views)
The best way (from my point of view) would be to override the test report callback. Then create a custom report using LabVIEW steps.
Another way would be to Browse the resultlist container to extract the needed infos.
Hope this helps,
Rodéric L
Certified LabVIEW Architect
Message 2 of 23
(5,211 Views)
Hi Rodéric,
Can you explain further how to create a custom report using Labview steps ? Is it working with .ini files ?
I am barely new in that Test Stand programming so forgive me my lack of knowledge.
BR,
Vincent
Message 3 of 23
(5,194 Views)
Hi Vincent,
I think you could use the step "Additional Results" in your sequences to customize your report.
Hope this help.
Sincerely
David S.| Certified LabVIEW Associate Developer
National Instruments France
Message 4 of 23
(5,192 Views)
Hi David,
I don't have hard yet to test that but it seems to fit my application. I let you know.
In Configure/Report Option i set up the following stylesheet ; expand.xls
That allows me to check my PASS/FAIL Sequnces in the format description above.
In my report i want to keep only my final test ; card is ok/nok. How to delete "if loop" pass/fail or "message" pass/fail report generation ?
BR,
Vincent
Message 5 of 23
(5,188 Views)
There is a check box called "Record results?" for each step.
Rodéric L
Message 6 of 23
(5,185 Views)
Yes indeed, for each addtional results set up.
But the basic report contain If loop report. I want to delete them in order to display only card PASS/FAIL.
You can find attached the kind of report Test Stand provides. As i don't have my hard yet. The report should display nothing. Here it is checking if If loop have passed or failed. I don't want that in my report generation.
BR
Vincent
Message 7 of 23
(5,182 Views)
Hi, I found the answer !
You click on your step/properties/Run Options/disable Record result
I have a last question, how does the template window work ? Seems you have to import .ini files but what for, what is the use ?
BR
Vincent
Message 8 of 23
(5,172 Views)
Templates are used to store a step or variable or sequence that you will want to use repeatedly.
For instance I always create a Statement Step.  Then I turn off the record results (as you have figured out).  Then I place that in my templates.  Then the next time I use a Statement Step I pull it from my templates.  That way I don't have to keep turning off the record results.  It is very rare that I record a Statement Step.
Hope this helps,
jigg
CTA, CLA
testeract.com
Message 9 of 23
(5,167 Views)
Hi Jigg,
Thank you very much for that feedback.
Test Stand begin to be more and more familiar to me.
Is there a way to get a report which fill in automatically, PASS / FAIL / NOT TESTED YET
The cabinet i am working on got 4 controllers with 20 cards on each. (80 cards on the entire cabinet, 960 I/O)
I need that kind of functionality in order to be sure all I/O have been tested.
Any idea about this (using expand/collapse graphical viewer)?
BR
Vincent
Message 10 of 23
(5,163 Views)
