NI TestStand
How to pass variables between Labview and Teststand
This is probably a trivial question but I am new to TestStand. All I'm trying to do is update a variable in Labview and then pass that value back into a Teststand local variable. A simple test vi is attached. I get no errors and it seems correct but when I monitor the variable through TS watch view it is not updating. Also I am not able to read the variable out of TS. It's probably a trivial thing i'm doing wrong but I'm stuck.
(3,727 Views)
Accepted by pdpeterson87
Nevermind, it was simple. Just needed to add the sequence context as an input and set to ThisContext in TS
(3,720 Views)
Why are you using sequence context instead of directly passing through the connector pane?
(3,700 Views)
