02-19-2016 04:04 PM
This is probably a trivial question but I am new to TestStand. All I'm trying to do is update a variable in Labview and then pass that value back into a Teststand local variable. A simple test vi is attached. I get no errors and it seems correct but when I monitor the variable through TS watch view it is not updating. Also I am not able to read the variable out of TS. It's probably a trivial thing i'm doing wrong but I'm stuck.
Solved! Go to Solution.
02-19-2016 04:16 PM
Nevermind, it was simple. Just needed to add the sequence context as an input and set to ThisContext in TS
02-19-2016 09:19 PM
