01-16-2014 05:50 PM
I understand the general idea behind modifying engine callbacks, but how can I figure out what the original engine callback is doing? In other words, how can I see the steps involved in the default TestStand engine callbacks? Specifically, I am working with the SequenceFilePostStepRunTimeError engine callback. I want to add functionality that executes when a particular error code pops up, but have the engine callback run normally (i.e., have the "what do you want to do?" window pop up) for all other errors. I am confused because when I first "add" the SequenceFilePostStepRunTimeError callback to my client sequence file, the callback is empty. Does this mean that my specific-error handling code is the only thing that will execute? Or will it execute in addition to the default SequenceFilePostStepRunTimeError code? How can I see the code behind SequenceFilePostStepRunTimeError?
I appreciate the help!
-Bennett
01-17-2014 02:01 AM
The engine callback are provided to the users to add in their code if required for that event.
By default it does nothing.Its just a place holder to do some extra things if required by user.
Its the TS engine code which runs in background and it cant be accessed.( unlike process model which is a sequence and can be modified by user).
For your use case add this in the SequenceFilePostStepRunTimeError callback:
if(Parameters.Step.Result.Error.Code == -17303) \\ whaterver error code you need
do what you want to do for this error code
Hope this helps.
Ravi
01-17-2014 09:37 AM
See this example:
<TestStandPublic>\Examples\Callbacks\PostStepRuntimeErrorCallback\ErrorHandlerExample.seq
In it you will see the comment:
"If this flag is set, TestStand does not send a UIMsg_BreakOnRunTimeError event to the GUI. This step sets the flag to prevent the GUI from displaying a runtime error dialog because this callback has already displayed a runtime error dialog to the user."
where the following is done:
RunState.Caller.RunState.ErrorReported = true
That is what disables the normal teststand error processsing. There is no default callback you are overriding, there is a built-in default behavior.
Hope this helps,
-Doug
01-22-2014 12:26 PM
Thanks to you both for the posts. I think I understand it now: it's the RunState.Caller.RunState.ErrorReported flag that controls whether TestStand shows the default runtime error box appears to the user. So, for example, I could do
if(parameters.step.result.errorcode == 1)
stuff
But if I don't clear the error by asserting "Parameters.Step.Result.Error.Occurred = false", or if I don't set "RunState.Caller.RunState.ErrorReported = true" in there, then the UIMsg_BreakOnRunTimeError event will occur, and the default error handling window will pop up. I tried that out in the example sequence, and it works as expected.
One more question on the callback in <TestStandPublic>\Examples\Callbacks\PostStepRuntimeErrorCallback\ErrorHandlerExample.seq: For case 3 "Go to Cleanup", the only step is to set the ErrorReported flag; no step in there says anything about going to cleanup. How does that work?
01-23-2014 09:08 AM
That's just the default behavior of an execution in TestStand when an error occurs if you don't clear the error (i.e. if you don't set Parameters.Step.Result.Error.Occurred to false).
-Doug
01-23-2014 11:23 AM
Got it, thanks
06-16-2022 07:09 AM
Thanks for this answer.
The example may have moved folders and have been renamed as I cannot find it on TestStand 2020.
However, the description given matches
<TestStandPublic>\Examples\Fundamentals\Overriding Engine Callbacks\Overriding SequenceFilePostStepRuntimeError Callback.seq
Just posting this in case it helps someone!
