NI TestStand
How to modify Report Format to 'XML Document' Using TestReport Callback?
I want to change Report Format to 'XML Document' by using TestReport Callback.
I know that I must use one of the fields of Parameters.ReportOptions, but I don't know what field  &
what should be the value.
Ofer
(2,894 Views)
Its ReportOptions.Format.
You can Override the Report Options which are set in the Configure | Report Options by including the ReportOption Callback in your Sequence File. Then In your ReportOptions you can set the Format by setting Parameters.ReportOptions.Format = "xml"
Regards
Ray Farmer
Regards
Ray Farmer
(2,889 Views)
Thanks Ray:
Now I know that this is the ReportOption Callback & not TestReport Callback.
Thanks for your help
Ofer
(2,874 Views)
