08-07-2020 02:01 AM
Hi
I'm trying to create a custom step where I have few set of data which test sequence developer can edit in TestStand (using pre-expression), but I also have other set of data which test developer should not be editing from TestStand (forbid in TestStand). How can I achieve this?
Usecase,
AJ
Ajay.
08-07-2020 04:00 AM
Hello Ajayvignesh,
You can add custom data to the custom step in Types window.
If you added the custom data, then right click on it, you can select Properties, select Advanced, the you can select the Flags for PropFlags_Hidden and PropFlags_HiddenInTypes.
If you have in TestStand the property unchecked to Show hidden properties, then these will be unvisible for the user.
