How to get the maximum iterations in TS property
I was set the loopType of one step to Pass/Fail count. For example "Stop after 1 iterations pass or after a maximun of 3 iterations. The Maximun iteration is 3. What my qustion is how to get the maximum iteration from TS property by test codes during running. Thanks very much!
Corey Chen
Test Developer from OPPO
(3,428 Views)
Accepted by Corey Chen
This may be a hack but RunState.Step.LoopWhileExpression has the information.  It will return a string like: "RunState.LoopIndex < 69 && RunState.LoopNumPassed < 5"
(3,414 Views)
Hi TSJim.
Out test step can not identify the "RunState.Step.LoopWhileExpression", Seems it is an unknown variable. Could you tell me how to utilize it ? Thanks in advance!
(3,400 Views)
Hi Jim,
It is OK now, I will be accept you suggestions. Get my usefull information from the specific 'String' . Thank again!
(3,394 Views)
