05-29-2018 07:23 AM
Hello, I'm running TestStand from python and every time I run the script it pops up to this screen , not only it's super annoying it also takes resources and has a negative impact on the time taken to access TS.
https://i.imgur.com/Qc5C0SZ.png
I am using only TestStand Trial with an Evaluation of 45 days.
I've tried looking inside .ini files for a parameter to disable it but I couldn't find anything.
Also 'Do not show this dialog again' is not clickable!
05-31-2018 05:24 PM
Hello Radu,
I am afraid that this window appears whenever you open NI software, under the evaluation version. Since you are calling TestStand using python, every time you run the code, this window will appear. One option though is for you to contact NI Support and ask them to send you a 30 day license. Depending on your project and what you are trying to accomplish you might get one to work on this period
Sebastián Ramírez
NI
