For TestStand 2012 and later the default process models uses a plugin architecture for reporting, hence why the report file path is easiest to access through the GetReportFilePath callback. This callback is executed after the client's MainSequence completes.
How can I access report file name and path before MainSequence ends. I need this beacouse my main sequence already have to know report file path?
