NI TestStand
How to get or Set the Container Values using For loop index ?
Hi All,
How to get or set the value from container in test stand using index value (for loop method),
thanks in advance,
saran
(2,976 Views)
To set the value to (from Container).
If you have a Container which has two fields Num1 and Num2 and you want to pass data from an array
Use:
Locals.MyContainer.SetValNumber("Num"+Str(Locals.Index+1),0, Locals.MyArray[Locals.Index]) (I have made the assumption that my types are numbers)
Now I have made my field names and types easy for me to do this.
You can use
Locals.PropName = Locals.MyContainer.GetNthSubPropertyName("", Locals.Index, 0)
Then use Locals.MyContainer.SetValNumber(Locals.PropName,0, Locals.MyArray[Locals.Index]). Again I am making the assumption that my types match.
hope this helps
Regards
Ray Farmer
(2,954 Views)
