Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
09-23-2021 10:46 AM
with "RunState.SequenceFile.Path" i get the path and filename of my sequence.
How can i get only the path?
So instead of "c:\temp\myfile.seq" only "c:\temp"?
Solved! Go to Solution.
09-23-2021 10:49 AM
Solved here:https://forums.ni.com/t5/NI-TestStand/Strip-Path-Function-directly-in-TestStand/m-p/3120821
Thanks!
We'll be in touch soon!
