NI TestStand
How to fix sequence editor error when using Test Executive 5.1.1 with Labview6.0?
I had a test sequence that was built with Test Executive 5.1.1 and Labview 5.1.1. The sequence test step vi used Test Shell to allow the user to edit and config the test. After upgrading the test step vi from Labview 5.1.1 to Labview6.0 by mass compiling all vi to Labview6.0, an error occurred while editing the test vi. The error is as following:"Sequence Editor Error: Config Test Vi Callback.vi: Could not config test vi. Make sure the path to the vi is valid." I am sure the vi path is valid, does anybody has any idea why the path was not seen? How can this bug be fixed? Any hints or suggestion would be helpful.
(3,128 Views)
Hello Redbean,
When you upgraded to LabVIEW 6.0, did you reinstall Test Executive? In Addition, did you mass compile the Test Executive LLB files found under LabVIEW folder? When you upgrade to a newer version of LabVIEW, it is better to reinstall Test Executive and Mass compile the folder in which you installed it and your Test VIs.
Finally, it is important to remember that Test Executive is no longer supported by phone or email. It is web support only. You may also be interested in checking TestStand, which is the replacement for Test Executive.
Roberto Piacentini
www.ni.com/support
(3,128 Views)
