11-17-2017 04:32 AM
i want to create an external file with some limits.
The file should be imported a teststart to globals.
In the limit teststeps i want to add a pre-expression that reads out the global and sets the limits.
The file looks like:
a_low=1.1
a_high=2.2
b_low=3.1
b_high=3.2
Currently i have a function that reads out the file content into a global string variable.
My question is:
Are there built in functions where i can pass this global variable + the name of a line (like "a_high) and it returns the numeric value behind it?
11-17-2017 10:41 AM
Is there a faster way than this?
Thanks for help
//Define Name to search in file
FileGlobals.Limit.LimitLowName = "limitname",
//1. Find Index of line in file
FileGlobals.Limit.IndexLineStart = Find(StationGlobals.Limits.FileContent,FileGlobals.Limit.LimitLowName),
//2. Find Index of separator in this line
FileGlobals.Limit.IndexLineSeparator = Find(StationGlobals.FileContent,"=",FileGlobals.Limit.IndexLineStart),
//3. Find Index of end in this line
FileGlobals.Limit.IndexLineEnd = Find(StationGlobals.Limits.FileContent,"\r\n",FileGlobals.Limit.IndexLineStart),
//4. Copy selection to step limit as numeric
Step.Limits.Low = Val(Trim(Mid(StationGlobals.Limits.FileContent,(FileGlobals.Limit.IndexLineSeparator+1) , (FileGlobals.Limit.IndexLineEnd - FileGlobals.Limit.IndexLineSeparator )))),
11-21-2017 03:22 AM
Hello OnlyOne,
please take a look at the property loader step type which is made exactly for your use case.
https://zone.ni.com/reference/en-XX/help/370052R-01/tsref/infotopics/redesignedproploader/
Best regards
11-21-2017 04:03 AM
thank you for the link. I already tested it. But it takes hours and 10000 clicks to do this for 500 teststeps.
So i simply created a loop that reads out my ini-file and directly creates StationGlobals of it. They are then used in the high/low settings of the teststeps.
I also do not 100% trust if the propertyloader is still working correctly if i delete one the 500 steps and create it new (= id changes).
In my solution i only have to reinsert the StationGlobal limit names and it will 100% work.
