NI TestStand
How to execute a store procedure using the database steps?
I'm trying to execute some store procedures and it won't work.
See the attached seq file.
I have a varchar(50) parameter which should also be supplied to the stored procedure and it will return an int.
(3,683 Views)
I did solve it. When I did use this string every thing worked with one exception.
"EXEC dbo.MySp @ID = 123;"
How do I extract the data returned from the statement?
(3,677 Views)
Accepted by topic author JohanHoltby
To do that I only had to use Data Operation on an open statement
(3,672 Views)
Hi @ JohanHoltby
Can you provide a working sequence file example
(1,956 Views)
