12-08-2015 05:45 AM
I'm trying to execute some store procedures and it won't work.
See the attached seq file.
I have a varchar(50) parameter which should also be supplied to the stored procedure and it will return an int.
12-08-2015 07:50 AM
I did solve it. When I did use this string every thing worked with one exception.
"EXEC dbo.MySp @ID = 123;"
How do I extract the data returned from the statement?
12-08-2015 09:24 AM
To do that I only had to use Data Operation on an open statement
09-04-2018 03:55 AM
Hi @ JohanHoltby
Can you provide a working sequence file example
